68 RR brake upgrade SSBC rotors Bendix calipers
68rules
1:33 PM
New York
Hi,
Im looking to put on the 68 bendix calipers im having rebuilt that I scorde a few years ago, not easy to find. I got the whole setup
rotors and all. The rotors of course are used up. These are expensive to replace as I found and I am not putting any A body stuff
on my b body, I dont care how readily available the stuff is, not gonna happen. So I happened to pick up SSBC calipers and rotors
a while ago. Wondering if the SSBC 11" rotors will fit the stock disc spindles with bendix calipers. The SSBCs are for drum spindles
and the disc spindles seem to be the same size. I dont see why this would not work. Thoughts ?
My own short answer is No. The SSBC hubs are shorter than the factory rotors to account for the caliper mounting they use. Suddenly I realized my Factory originals are not that bad after all....
Also would question the centering of the rotor required when running the Bendix.
