69 Charger wiper motor crank? / Lever?
Stucat
7:09 PM
Good evening looking for info and part number for the correct wiper motor crank arm or lever on a 3 speed wiper setup? Also is it just a 69 only part? Or would other's fit. Couldn't find any info in the 60 service manual.
The wiper arm number is 2822273 and I believe its for 69 and 70 B body only. Make sure you have the correct wiper motor for a 69 B body because they changed shaft sizes and different offsets depending on A B or C body and your wipers wont work correctly with the wrong combo. I just converted my 69 Charger to a 3 speed and found most of the parts on Ebay.
The motor is 2983116 which is correct for late June 69 build
thanks for the info, just had the motor rebuilt
I have a late model motor on my 69 and found a date coded one. I got the arm from Bill Peake. I use him a lot for new and used parts. Also does wiper motors and power steering pump rebuilds etc.
