69 Super Bee EFI Conversion Plan
I went with the complete Tanks INC setup
note this is my 66 Charger
Their vented tank makes filling much easier as it isnt vented back into the filler tube
The 66 & 67 are famous for fuel gauge problems with aftermarket sending units
So I went with the float-less sender
I chose the GPA-4 in tank pump which supports up to 630 horses (your Holley is only 550)
I have 1/2 inch fuel lines to the fuel log and 3/8 return line
The main difference now is I went with a regulator for a Carbed setup
& had a custom carb built by Dominic Thumper
The decision to go with the carb was made after reading some of the drawbacks to the EFI systems
I do have an AFR gauge
I am extremely happy with my setup and would do it exactly the same way all over again
I phased my lean burn dizzy the old fashioned way, cut a slot in the housing to adjust it. I'm not sure if I would have had spark scatter or not if I hadn't but it's been fine this way.
Are you talking about the cap?
You can make a new offset slot in the reluctor wheel where it pins to the shaft to also change the rotor phasing of a stock type distributor.
I slotted the housing to adjust where the plate was fastened to the body in relation to the cap.
Furious70, could you explain in more detail how you accomplished this?
Oh boy ..I did it in 2008 lol
The plate fastens to the body with a couple screws. I set the dizzy in at the 60* btdc and then marked where the rotor was and then based on where the cap was for #1 I think I split the difference by slotting the body so the plate could be rotated a bit.
Are you saying that you slotted the holes in the distributor body for the plate screws so you had adjustment one way or the other?
I learned it from a mentor in the hobby who had been running a turbocharged small block in a Challenger for 20 yrs
I was under the impression that you were currently using the MSD system. It should come with installation instructions. I was just suggesting a source for constant 12 volts to power the EFI.
Mike
Today I checked what 12v source my MSD box is running off of and traced it back to just one side of the ballast. So I checked the voltage on the ballast and it's about 11V on BOTH sides with the key in the RUN position but motor off. Does that mean that the professional mechanic who installed the MSD somehow bypassed the ballast but kept it installed? There is no jumper form one side to the other.
If the ballast resistor is no longer connected to the ignition coil then it no longer has a load. None or very little current going through the resistor, so no voltage drop. The MSD key-on sense wire is likely pretty high impedance, and uses very little current, so if it was on what was the coil side of the ballast resistor the voltage would be slightly less, like maybe 0.1 volt or so, than the key side.
