69 Superbee Hemi Orange = Driveshaft
Rustymopar
5:22 PM
Stevensville, Maryland
So I did a little playing around with the timing and carb. I got it running the best its run since
the build was complete last summer.
So I was feeling like a tough guy and dumped the clutch and snapped the driveshaft up close to the
trans.
What is a good strong balanced drive shaft - factory length but stronger?
Any links appreciated.
trans.
Actually its just the Yoke and U joint. Is there a tougher one then stock out there?
And lastly - a factory 4 speed trans (A833) for a B body had a 25 spline front yoke? correct?
Inland Empire Driveline Services. I just had them do one for me.
http://www.iedls.com
I wrote about it here:
http://www.forbbodiesonly.com/moparforum/showthread.php?36174-80-Grit!/page6
Dyno-tech in Michigan, free shipping, great quality. Their steel shaft will be more than enough. I own 3 of them, two steel, one aluminum. The aluminum one holds up behind my 572 64 Belvedere, 1.25, 9.04 @
151
trans.
Input splines should be 23 for the regular 833 and 18 for the hemi version. Output splines for your year should be 30, same as the 727.
