70chall440
- 3:24 AM
- Feb 11, 2018
- Yelm, Washington
I have been building/repairing a 69 Ply wagon for a friend/client for quite some time. What started off as a relatively simple task morphed into a very lengthy and some what complicated effort. This car started life off as most did of this time, basic /6 AT car however the owner installed a 440 6 pack and a 4spd. I had originally agreed to install a Fitech EFI 6 pack and replace the wiring harness, however this target moved onto replacing the 3rd member, putting in 4 wheel disc brakes just to name a few. Anyway, one of the things I agreed to do was build some type of console for the car because the owner wanted to use a double DIN radio and he wanted cup holders. Keep in mind that that the car is a bench seat car (which he is retaining).
After some thought I decided to build something that paid homage to the original consoles of the era and set about designing and building one. I began using 1/4 rod (onlinemetals.com) and build a sub structure, then using 18g sheet metal built the top, front and side plates. I used 1/4" high carbon square stock for the accents and then used woodgrain shelf paper to finish it off. The cup holders are from Amazon (marketed for boats) and I built in a fuse subpanel that is located on the passenger side in the front and has 2 thumb screws holding the plate on. I also mounted the Fitech controller inside and underneath the stereo.
While this build was tedious, it was not super difficult, about the only expensive tool I used was my 110V mig welder although I admit that I did use my mill to cut the holes for the cup holders and activation button but I did use a basic hole saw (just easier on the mill).
I thought some of you might be interested so here it is. Once I get it mounted in the car I will try and remember to get a pic and post that. The following are pictures of the build and the final product.
