SOLD 70-74 BB 10.5" alum. 513 casting bellhousing
mattsmopars
6:35 PM
middle tennessee
Feedback: +9 / =0 / -0
I have a 1970-74 big block mopar "513" casting aluminum 10.5" bellhousing for sale. It will need some repair, but would be a good bellhousing when done.
It has a crack starting at the bottom of the clutch fork hole. It should be an easy repair as it does not look to go all the way to the clutch fork hole.
Also the lower passenger side hole where the trans would bolt to has the top portion of the threads pulled out, but the lower threads look good. It might be ok with a bolt long enough to catch the good threads. The drivers side has two holes in need of a repair. The lower starter bolt, and the lowest bolt to the engine. I think they will need a heli-coil to repair the threads because the threads look weak. Would be a good bellhousing with some work.
Asking $125.00 plus the shipping from middle TN. I can email more pictures if need be. Please PM me if interested. Thanks, Matt
