70 GTX Decoding/need some help.
WISCOPAR
6:10 PM
Wisconsin
I'm fairly confident in my efforts below....but not all codes are in the "red book". Can anyone help me with the BOLD codes below? For sure wondering on the UDG color/TX9??? Is this the dash???? My car has a black dash, I know they came with wood grain. Hopeful this is correct for my car.
Also the gear ratio.....Is this accurate??
Any and all help appreciated.
1970 Plymouth GTX
VIN: RS23UOA156012
FENDER TAG:
4/upside down
23125 155 188 N
114 082 676
26 C16
FE5 L31
FE5 P6XA TX9 A31 078963
E86 D21 RS23UOA156012
Build sheet breakdown:
155015 Sequence #
A31078?63 Vehicle order #
R Plymouth Belvedere
S Price class/Special
23 Body type/2 door hard top
U Engine/440 CI 4V V-8 375 HP
O Year/1970
A Build Location/Lynch Road
156012 Sequence number/VIN
Y05 Built to US specs.
E86 440 4bbl
D21 Manual 4-speel transmission
D56 Axle/3.54 gear?
D91 S/G 1 Sure Grip Axle/Posi
T87 Tires/F-70-14 R WT
P6XA Vinyl bucket seats/Charcoal black
TX9 UDG color? Black Velvet
01 Paint type/Monotone paint
FE5 Rallye Red
FE5 Roof color rallye red
315X91005 Steering Column
?8X9 Steering Wheel
43X9 Steering pad
RAD56 3.54 Dana 60
57 Inlet hose
72 Alt
?6 ???
FanSpa 70
BAT 69
V6W White Sport Stripe
27 Vac Fit
114 Eng
53 carb
676 trans/18 spline Hemi 4 speed
36 PIN
560 p/shaft
082 axle
63 road wheels
TX9 black velvet color
16 spare
24 wheel cover
79 Frame/K frame
62 .88 sway bar
56 front shock
92 rear shock
23 front brake
781/780 left/right torsion bar
794/964 rear spring left/right
59?0 Clutch/break pedal
53 Idle label
68 tire label
00/02 exhaust left/right
14/13 tail pipe left/right
M5 car height
1-57 ??
2-17 ??
3-56 ??
A01 light package
A33 Track package???
B11 HD drum brakes
C16 console
c233 rear arm rests with ash trays
C55 bucket seats
C93 carpet
F25 70 Amp battery
F966 oil pressure gauge
G41 Mirror????
H11 Front heater w/defrost
J11 glove box lock
J15 Cig. Lighter
J25 3 speed wipers
J31 Dual horns???
J64-4 Wood grain??
L05-5 Map light
L15 ash tray light
L65 Ing sig. time delay
L76 Heater control lamp
M21-1 Roof drip moldings
M26 Wheel lip moldings
M81 Front bumper guards
N41 Dual exhaust
N42-2 Bright exhaust trumpets/chrome box tips
N65 Clutch type 7 fan??
N51-1 Max cool fan
N85 Tachometer/clock
R11 Solid State AM Radio
S15 Hemi x HD w/sway bar
S25 Heavy duty shocks
W23 Chrome style road wheels
Of course, if you see any errors in the decoding, by all means let me know. Just trying to get to the bottom of it's original pedigree.
your a33 is a 3:54:1 dana 60. the a34 is a 4:10:1 dana. patti,Denison,tx./ thx
Thank you sir. I'm thinking someone switched out the rear gears at some point. Two of my cars have 3:23's. I like these for cruising for sure. The GTX is for sure not Highway friendly. In the 11 years I've had it, I've never been on a highway with posted limits over 55mph. I've never had a 3:54 gear, but I can't believe it's that much change from the 3:23's. I've driven the Charger from Seattle to wisconsin on I-90 before. 85mph for hours straight in Montana....no problem. I'm guessing someone threw 4:10's in the car. Guess I'll have to tear it down and see.
