70 super bee power buldge hoods
7:04 PM
winchester va
hi every one i own a 70 super bee with the power bulge hood,i have several questions,first can any one post pics of what is supossed to be in the openings ? ive seen several cars but none that had the factory parts that keep water etc from going thru,was there such a thing?there is holes so something must have been there ?if i go to a cast iron six pack intake and repro carbs and 6 pack air cleaner will i run into hood clearance problems?i set a new eldebrock perfomer high rise with holleyto see if it would clear and couldnt use my factory air cleaner so i returned the intake and am running a factory cast iron 4bl intake at present.would like to use six pack on my fresh 70 hp 440 but dont want to layout the cash and find that it wont fit under my stock hood.changing to a lift off hood is out of the question.id consider changing to a ram air hood but id prefer to keep my original hood thank anyone that could help .brendan:sunny:
I'll hook you up with some photos this week. I am running a factory cast iron six pack intake and carbs and clearance is not an issue with a power bulge hood! Pictures coming, but for now I must get back to work!
Hey guys I'm in need of a little help and I hope this is the right place. I am running into some of the same issues as superbeegrandprix has. I have a 70 Super bee with a power bulge hood and like all of them I have seen mine is open to the elements (rain, fog, ect.). The car has the original HP 383 and dual horn air cleaner. I have recently found a partial set of scoops on ebay with the drains which I bought. I have been able to piece togeather the part numbers for everything but two pieces. The two part numbers I am missing are for the vertical plates that mount into the opening of the scoop with two screws each. I have an original Dodge repair manual and all it shows is the ram air hood set-up. Any help on part numbers an\or sources would be greatly appreciated. Thanks in advance!
Respectfully,
George
1970 power bulge hood p/n and photo
I believe that you may be looking for a set of these? #2998397 and #2998396 I believe they are called rain deflectors and they are held on by two bolts per deflector.
Here's one listed on eBay. I had a '70 Coronet years ago that was missing the parts. I cut two pieces of aluminum that I got from Home Depot and painted them satin black and bolted them in. I didn't know what was missing either at that time but didn't like the rain going stright through. They weren't perfect, but they did the job, and if I can recall that far back I bolted them in with two bolts, also. I made them long enough to clear the upper part of the 'bulge'.
There's one listed on ebay, I can't post a link yet, but search "super bee power bulge" it's blue, item # is 261029477514. I had a '70 Coronet years ago that was missing the parts. I cut two pieces of aluminum that I got from Home Depot and painted them satin black and bolted them in. I didn't know what was missing either at that time but didn't like the rain going stright through. They weren't perfect, but they did the job, and if I can recall that far back I bolted them in with two bolts, also. I made them long enough to clear the upper part of the 'bulge'.
