WTB '71 Roadrunner dash
popslavaz
5:55 PM
Channahon IL.
Feedback: +15 / =0 / -0
Wanted to buy '71 Roadrunner complete dash frame with speaker cowl piece.Going to build a complete fresh dash to install this next winter. Hope to find one close for pick up to avoid steep shipping charges for oversize.No hurry just getting started.
Thanks
POPS
Is this similar to a 71 charger? I have a couple of these if so.
I really do not know if they are the same or not.I bet someone will jump in and let us know. POPS
Pops, I am going to Mopars in the park in Minnesota. We may be able to get a friend to deliver. I have a buddy in Chicago that may attend. Anyway we need to see if the frames are the same. I will ask around. Whats the chance you have some A/C lines for a 71 b body?
have a couple in michigan,will be going to the mopars at the red barns gilmore classic car museum
71-74 b body dash are all the same . Small things changed like on the gauge bezel but that's it . I have a frame extra but in FL.
Pops this is not true. You need to tell us what you are working on as there are 4 dash frames. Regular frame, A/C Frame, A/C Frame with 4 speed. Regular frame with 4 speed. A/C frames have a spot cooler located on the left while regular frames are solid there and 4 speed frames have a hole in it to the right of ashtray for the reverse lamp indicator. Of course it doesn't matter unless you want to weld patches in a frame to make it correct but it's easy enough to get the right one first. I have a few here in Pa.
Also 71-2 glove box door has a stop bar and 73-4 has a cable thus different frames.
Also the reverse light on 4-spd cars was part of the AO1 light group so not all cars have it.
This is true but all is easily modified ,but as for the frame structure it's all the same more then 99% of the frames that are available are a/c and for an auto car just get what you can get, Around you. A spot weld is easy and a cut off wheel will make a non ac dash ac again I have a a/c dash for an auto if you want one .
Sorry for the confusion I was really just talking about the frames fitting in the cars .
It will be for a '71 non air, 4-spd car. I can add hole for shift light if needed.
POPS
I have one here in Pa. but shipping would kill it. It's a 72 black frame non a/c.
