99ss
Whats the best way to go if you are going to mod the appearance a bit anyway.
I am going to get the 71 RR 99.9% sure and I am planning ahead right now.
I can get the car with a 66' 383 complete engine none running, no trans.
I am going to add chin spoilers and the rear wing as well as I like the look. The car is plum crazy purple from the factory. automatic column shift car.
Should I look for a date correct drivetrain and restore the car to oem specs?
What categories can I enter in a car show if I mod it slightly like that?
Is it better to have a numbers matching car or would a date correct 440/6 packs still retain as much if not more value to the car?
I was thinking of adding a 440/6 pack and 4 speed instead of the column shift and 383.
