71 satellite tank in a 73
chargers777
7:57 PM
nashport ohio
Will it fit Looking to get rid of the 4 vent lines as my emision stuff is unhooked anyway and that tank is much cheaper.
It still has 4 vent lines, they just come out the rear drivers side of the tank. Theres 1 line off a vapor seperator on the shock crossmember that takes the vapors to the engine compartment. You should (at the very least) put a little mini filter on that line, if your not going to plumb it into the engine via manifold or valve cover breather. Theres no need to swap the tank, and a 71 tank will not help.
I'd run it into the carb, as intended.
Mine is currently bypassing the charcoal canister and that hasn't caused any issues, it just goes straight into the carb and helps with MPG.
If you're running an aftermarket carb, you should be able to use which ever vacuum port you're not using for the advance.
As intended? It was never intended for the fuel tank venting to be directly connected to any carb port. How is the hot starting on hot days plumbed as described? There is a reason the charcoal canister is still in use today. The ’73 and later OE carb timed purge port is balanced, the timed port for vacuum advance is not balanced and is not intended to be used as a purge port.
An intact evaporative recovery system/fuel tank vent system, as originally designed, is not a detriment to performance in any way.
71/73 tanks are physically the same, with just differences on the vapors system. If you are not going to use it, you can use any one of them on any 71/79 model.
Mopars on Vzla never got the vapors recovery system and used same tanks you got, so that won't be a problem.
74/79 are diff monsters and won't fit on 71/73 due the hump on tanks used for vapor system redesign.
The next diff will be if single or dual exhaust. Single exhaust are tipically used on low perf cars and they are wider on left side. Repros are anyway all made to dual exhaust.
I have no issues starting on hot, extremely hot and humid FL days in excess of 100 degrees and 99% humidity.
The only difference is that I don't have the canister in place to store the vapors.
They go directly to the fuel bowl. I suppose that is different than directly to the metering circuit or wherever the timed/direct ports go.
It's a minuscule amount, but does help, not hurt.
I have an AFB/AVS upgrade waiting and had planned to do as I described. I guess we'll see.
71 didn't have a charcoal canister. The line from the vapor tank in the fender well went to the 3-nipple cap on the valve cover and then to the carb bowl.
“then on to the carb bowl”
To be clear, the enclosed carb bowl vent nipple does not intake or collect fuel vapors. The fuel bowl vent valve is another source of evaporative emissions to be collected while at rest, for ‘71(and California ’70), these vapors were stored in the crank case to be consumed/purged though the PVC system on start-up. Connecting the fuel tank vent line directly to the float bowl vent valve nipple can only lead to fuel vapors collecting in the air cleaner at rest, normally resulting in hot start issues for a correctly tuned motor.
The one year only ’72 four-nipple charcoal canister also purged through the PCV line, ’73 and up 3-nipple canister depended on a dedicated timed and balanced purge port on the OE carbs to route the stored vapors to combustion.
