Okay, I don't know the length, do you want me to measure the area that receives the molding?I have the rear pieces for sure and the side pieces just need to know the length to make sure. The corners are reproduced I would buy them new...
71 is different.Yes cause I don't know if those qtr. panel pieces are the same on 71 Charger with door belt moldings.. The side trim is not marked but is for door belt molding for sure and I don't know if they are different or same length due to the window difference...
Here is a 71, the molding meets the belt molding at the corner.Yes cause I don't know if those qtr. panel pieces are the same on 71 Charger with door belt moldings.. The side trim is not marked but is for door belt molding for sure and I don't know if they are different or same length due to the window difference...
I have a set with one broken corner if things don't work out.
I have the broken piece and I believe JB Weld will fix it so it can't be seen.
