WTB 72 Charger Full vinyl top moldings
NoCar2023
9:57 AM
CA
Looking for these moldings for a full vinyl top.
72 SE coupe/hardtop appear to be the same.
Thanks.
Here are the 6 pieces I am missing.
I have the rear pieces for sure and the side pieces just need to know the length to make sure. The corners are reproduced I would buy them new...
Okay, I don't know the length, do you want me to measure the area that receives the molding?
Yes cause I don't know if those qtr. panel pieces are the same on 71 Charger with door belt moldings.. The side trim is not marked but is for door belt molding for sure and I don't know if they are different or same length due to the window difference...
71 is different.
I will measure and post pics.
Here is a 71, the molding meets the belt molding at the corner.
I think a 71 WITH door belt moldings is a different length...That trim piece shown is different cause it is "open" at both ends to transition to the other pieces where the V. Top side trim is tapered to a finished "point" where it meets the door belt trim...
I see, the 71 pictured has NO belt molding, I am searching for a 71 with belt molding.
Found one.
You are correct sir. appears to be the same for 71.
I have a set with one broken corner if things don't work out.
I have the broken piece and I believe JB Weld will fix it so it can't be seen.
Ok, thanks.
Here are the side Qtr. pieces. If they are what you need I will post pics of the back pieces.... Pm and let me know and we will go from there.. Thanks!
