72 Charger Guys
63RedFury
5:57 PM
Montgomery Alabama
I have been looking at some Chargers.On a 1972 Charger SE it has the small side window behind the door.My question can this be made into the normal big window?Is there a fiberglass plug under the vinyl top?And if there is a fiberglass plug can it be removed and the normal size window and trim be put in ?I do not like the looks of the small window.
Thanks,Jim
I had a 72 SE and under the top is a metal filler tacked in place over the none SE window opening. The window is the same, you just cant see it all. I cut this out and got the trim from a none SE. interior panel is also needed. Its an easy fix.
If you do this, please post photos as you go, just to satisfy my curiosity. You will definitely have a unique look with the standard side window combined with the SE roofline/rear window angle.
Its the same body line after you remove the filler panels. I just did this and you also have to extend the drip rail.
