72 Heater Box removal
TopBanana72
12:07 PM
Ohio
Hi All, I need to remove the heater box to fix a core leak. How does this thing come off?
In any case not from that side... The motor comes out along with the complete heater box.
Just did that job on my 71.4 nuts on engine side of firewall, one rod inside on top left of box, and all the control cables need to come off, then you take out the box.
SO that black thing the arrow points to... I don't do anything with that?
Just remove the rubber cold air hose and the motor will come out with the box as mentioned above. Pulling the glove box liner really helps when pulling the box.
Oh I see, thanks. My first time doing this.
Another trick I read here and highly recommend: by all means, take out the passenger seat first. Your back will thank you!
Oh thanks!. I was thinking of that. I have a bench seat :( Still might take it out though...
Make sure you are careful getting the nuts off in the engine compartment. You can bust them out of the fiberglass housing if they are seized. I have cut the nuts off with a cut off tool just to insure not breaking them off and then bought new nuts..
