BlooDSMeaR
When I did adjust the front band, I first tightened the adjuster to 72 inch pounds, then backed off 2 full turns. It was still stopping the wheels on the 2-3 shift. So I loosened it in 1/4 turn increments out. Even with getting the front band adjusted enough so it wouldn't stop the rear wheels on the 2-3 change, the trans would cut loose on the slightest blip of the gas peddle.Had the same problem. With the car on jack stands I could see the tires stop completely on the 2-3 shift. Adjusting the rear band helped tremendously.
TCI is Being very helpful with helping even though the warranty period is up long ago.
