FOUND 727 kickdown carburetor rod
Huicho417
7:53 AM
San Antonio , Texas
Feedback: +0 / =0 / -0
I converted my 67 coronet from the original 2 barrel carb to 4 barrel edelbrock. I had to purchase a longer throttle cable along with the bracket that mounts on the intake from 340/360 to make it work. Now I need the correct rod that hooks to the carburetor, like the one on the image. Mine is the one original to the two barrel and does not have the bend to align the geometry correctly. Let me know if you have in please.
Every thing is too short on a 2 to 4 barrel manifold conversion. The linkage setups where different almost every year. year of car and engine and linkages.
Not sure. It’s what the car has now. So far I have changed to a longer throttle cable to reach the carb stud and the correct throttle bracket that’s mounts to the intake. Just want to get the correct rod.
No, they will not work. The angles and bends will not fit my layout. Thank you very much though for sending the pictures, really appreciate you taking time out of your day to respond. I actually found one on e-bay earlier and purchased it.
Please mark this thread "found" just below the title.
