Evan Frucht
When going up hill my 64 Fury is making a loud clunk or bang which sort of shakes and shudders the whole car as it happens. This happens when I accelerate up the semi steep hill that is my street. And it only happens for a moment and then goes away.
When car is revved up in neutral or park it sounds very smooth with no vibration or sounds whatsoever.
I thought it may have been the old ball and trunnion drive shaft which was clearly worn out. I just had a brand new custom drive shaft with a slip joint and double U-joints made and installed it. Paid 400 for it. All brand new and balanced. It might have reduced some vibation's a little, but the high load bang/clunk is still there.
The car has its original 318 poly/push button 727 combo
PO told me had the engine, trans, and rear end rebuilt but had no paperwork becase it was aparrently lost in a storage unit. I sort of believe him given how well the engine runs, but something isn't right in the transmission, or possibly rear end--but that seems less likely than trans. It isn't making any grinding or whiny noises.
The ATF fluid level may be a little on the low side but it was shifting through all the gears properly it seemed.
Could low fluid level cause a loud shuddering bang?
Any ideas what component in the transmission may be causing this?
