727 Reverse Manual valve body - transmission linkage location
inri
10:30 PM
Sacramento
Hello again,
I will attempt to install the gear vendors unit soon onto the 727. It has a reverse manual valve body and the GV instructions say to make sure the transmission is in 1st or L gear. I looked online and can't find an illustration of where the transmission arm would be on a 727 transmission that has a reverse manual valve body.
The trans is new from Cope and right now the linkage on the trans is all the way forward (towards the engine). Im not sure if this would put the trans in 3rd gear or Park. Reverse valve body is P R N 1 2 3. So if forward is P or 3 I can work my way to where the transmission arm should be in 1.
Thank you.
