727 tranny leak front
pjm8047
9:52 AM
Clay,NY
My 727 transmission seams to leak a little bit when it warms up in front bell housing.I took the dust shield off and it looks pretty dry in there.Is this normal or its it a bad seal?I had the radiator replaced last year.Is it possible that the shop over filled tranny?
If it was leaking in the Bell housing it would not be dry inside after removing the dust cover.
Is it possible that something is like from the outside of the transmission and the tranny fluid is just collecting at the bottom end of the bellhousing?
look closely at the filler/dipstick tube, it may be the O seal
Ill have to check that out.I hope that was it is. Alot cheaper then dropping the trans.If it is leaking.Can I buy it at a napa,autozone,..... part#?
