727 trans oil level question.
440 Charger
8:42 PM
naples Fl
Does anyone know oil level full mark in relation to the transmission case. I have to cut down and remark a dipstick the old was rotten and gone. Looks like the pan mounting is about correct trying to double check if anyone knows thank you.
My 727 stick is 18&3/4" from tip to cap top
18" from tip to 1st or lower stake for washer.
Full mark is 1 & 3/4" from tip
Add 1 pt. Mark is 1 & 1/8" from tip .
Stick tube is 18 & 1/2 " to top.
That was measured with a tape and hooking the bottom inside edge. So that tube number could be give or take a 1/4.
Perfect thank you very much.
