727 transmission support bracket
fwi
2:12 AM
BHC Arizona
I am installing a 727 out of a 1969 into a 1965 coronet, as the trans support bracket and the rubber mount are shot I need to replace those 2 things. What years will fit?
The cross member and rubber mount are 62-65 Early B body parts. I believe automatic and 3 speed are the same cross member. I go my rubber mount from Imperial services.
Matt
I am just wondering if the 69 trans mounting holes may be different...
62-65 mounting hole spread on the tail shaft is not the same as 66 and up.
Doug
