73 Roadrunner big block oil pan
satarunner
9:07 PM
Boise Idaho
I have a 73 Roadrunner factory small block car that I'm putting a 440 in with schumacker mounts and the factory small block K-frame. Does anybody have a picture of the oil pan that will work for this project ? I have a couple oil pans but I don't see any numbers on them.
Oil Pan
You need a part #3614970 fits 73/74 B Body 400/440 stamped 971, I would replace the k frame and torsion bars, they will be larger in diameter for extra weight
Where are the markings on the pan ? I've seen some pans that have the numbers embossed on the bottom but mine don't have it. I know I should have use the big block K-Frame but I already have the schumacher mounts for the small block K-frame. The big block K-frames are not the easiest things to find in my area.
0il pan
Call Mark at ,but not after 9.00 P.M. has lots of mopar 73/74 Parts.
