73 RR bent frame rail (front passenger)
rawhead
New Member
9:11 AM
Transilvania
So this is my first project. the biggest issue so far being the front passenger side frame rail is tweeted. My question is, if this can be fixed by a body shop, or do i need to pull a "new" one off my parts car? GEDC0426.jpghere you can see the dented frame rail
GEDC0424.jpgabove the rail where the sheet metal has splitGEDC0425.jpgwhere more damageGEDC0427.jpgand this is the undamaged side.
My driver's side frame rail was bent by steering gear box and I had body shop put on frame machine and pull it back in specs. Worked great.
a good auto body tech can repair this damage ,be sure to check the shop out don't take it to some one that doesn't have the correct equipment
