doublekrossd
Hi all. I'm looking to change the gears in my 489 cased 8-3/4. Currently, it has a 3.55 in it but it sure could use some more gear. I'm thinking about going to 3.91 but I'm not sure if it would be a big enough change. If I go to a 4.10, will it bolt right in, with proper adjustment, to the existing carrier or do I need to change more than just the ring and pinion gears? If I recall from years ago, in a Ford rear, if you went from a 3 series gear to a 4 series gear you had to change carriers, that's why I ask. Will a 3.91 make a big difference in the way the car launches from a stop over a 3.55? I'm not overly worried about highway cruising as it is only a local hot dog and ice cream getter with a rare trip out to the local dragway. Currently, the car is running about 2000-2300 somewhere around 55-60 mph. The motor is a 440 with an indy top end and it really likes to run above 32-3500 and seems to pull hard all the way up to about 6200.
just looking for some previous experience from all you mopar experts before I have to buy several sets of gears and a mechanic to install them. Thanks in advance!
