8 3/4 question
mopower440
6:42 AM
TN.
There are 2 gaskets for the ends of the rear end, both with 5 bolt holes. 1 is a white foam type gasket and the other is a tin gasket. which one goes between the backing plate and tube housing and which one goes between the actual splined axle and backing plate? Also, any RTV recommended anywhere? Looking at the instructions on the FSM, it doesnt really say which gasket goes where.. Thanks!!
Foam between tube & backing plate (outside), and the metal goes between the backing plate & the adjuster plate (inside).
From the FSM.
