8 bolt crankshaft
dancingsteven
12:03 AM
Abilene Texas U.S.A.
I have a 8 bolt crankshaft in my engine and I notice that there as once a dowl pin used to guide the flywheel onto the crank but it has either been broken off or was knocked off! My question is can these be removed and replaced with a good one or was it part of the crank? The next question is how important is this pin? Once the flywheel bolts are torqued down the flywheel is not going anywhere!
The bolt pattern only allows the flywheel to be bolted on one way, right, just like a 6 bolt crank.....
