petieg383
So I've had my 70 RR for a few years. Over the past year or so I've noticed the trans is acting up. It started to pop out of 3rd gear when decelerating. Then it started to do it in 2nd gear. I get under and look at it and notice it's only being held into the bellhousing by the top 2 bolts. Ungood. So I put new bolts into the bottom and tighten the tops ones. It seems a lot better at that point. Now over the past few months it starts popping out of 3rd again when letting off the gas. When accelerating, it never comes out of any gear. Back in December it starts to make some ugly noises when driving it and when it's sitting in the garage. When I push in the clutch, the noises go away. So I'm trying to pull the trans now to inspect and possibly refresh it. Again when driving it's been fine up until a few weeks ago so I'm hoping whatever it is, it's minor.
Here's the issue:
Got the following items unbolted: Driveshaft, crossmember, speedo cable, clutch cover is off as well just in case. I took out the 4 bolts that go into the bellhousing, which by the way were way loose again.
Trying to pull the trans out it seems like it's binding on the clutch fork/throwout bearing. I also think I need to remove the shifter to slide it back a little further, but it really seems like it's bound up on the fork & bearing.
Is there something inside there that I'm supposed to remove? What am I missing here? I'll try and get a pic up on here a little later on.
Here's the issue:
