biomedtechguy
Accelerati Rapidus Maximus
- 5:15 AM
- Mar 28, 2014
- South Louisiana
I will be sending my 18 spline a833 back to have this problem resolved unless someone can suggest a fix for this problem. Not every time, but often enough 2nd gear pops out. Seems to happen under "low stress" conditions. Never has happened when wfo on the throttle, tried "on-and-off" the gas pedal expecting the "off" cycle to make it pop out. Typically it is during a turn where I am barely or not at all on the gas, or when barely on the gas going straight. Other than the dreaded worn 2nd gear senario, what else can be the problem? Shift rod for 1st/2nd adjusted 3 times, each time progressively "pushing" the 2nd gear dog further into the engagement direction for 2nd gear...final adjustment was the opposite of that in that I used a shifter alignment tool pushed through the holes in the shifter in neutral and adjusted ALL shift rods so none of the collars binded when I put them in the holes.still having the problem under light throttle.
