915 head needs repair
Garys1969RR
1:02 PM
Colorado
Any one know how to repair a hole in an intake port, going into the water passage?
Ok thanks! Was nt sure if J B Weld would work, but that Marine Tex must be durable with water on one side, and Fuel/Air on the other? Do you get that at a Boat repair supply? Have nt heard of it. The 1/4 inch hole is in the intake bowl near the valve guide.
if this hole is from erosion, or cavitation, you may have other thin spots. a replacemnt head isnt that expensive to consider.
Marine- Tex is a good product, or Belzona the top end product. This speaking from 20 years in Alaska fishing industry.
Hole is about 1/4 inch diam
I ported the bowl too far, hit water
915 head, hole is near valve guide
Thats what my buddy did while porting his 360 heads for his racecar. He used JB weld & I toldhim it wouldn't work. Well that was my mistake, he ran it all season in a challenger turning low 11's, man he didn't let me live that down!
Ok going to have 1 head hot welded, the other small hole, JB WELD. See what works.
What concerns me about welding is if the surrounding metal around the hole is really thin it will blow away as soon as the welding begins, leaving even a bigger hole. If you use an epoxy, the area to be repaired must be super clean, and I don't mean wash with solvent and blow dry. I think it needs to be chemically cleaned.
problem with posting reply
Meep Meep, would Brake clean be adequate?
And then light sanding?
Or Acetone as a cleaner?
What type cleaner?
Some type of acid?
Ok ordered some epoxy putty from Summitt
Specially made to repair intake ports
Called Manley magic seal epoxy
Hopefully the solution to this problem!
I have not seen many people in my lifetime that can successfully weld cast iron. Maybe only two. ONe is still alive and even he says cast iron welds are a toss up as to whether they turn out. Good luck.
Hmmm, sounds spot on for the application! Good luck!
Backed off on the welding idea. Prob ruin the head beyond repair. Will stick with epoxy.
