EngineerDoug
I built a 727 to go behind my 493 stroker and have questions about the resulting shift points. Here's a quick rundown:
1974 Torqueflite entirely rebuilt (my first time) using top quality parts from a very reputable transmission builder. Built to easily handle the ~550 hp of the stroker.
Includes new street/strip valvebody.
Using a Bouchillon kickdown cable setup with their supplied 6 pack throttle bracket.
Kickdown cable adjusted so that WOT at the carburetor leaves 0.100" slack before trans throttle lever is full back position.
Converter custom built by Dynamic Converters, about 3000 rpm stall.
Engine is a mild 493 using a mopar 528 solid lifter cam.
OK so I have a hundred miles on this combination and am puzzled by the shift points. If I drive it around town = easy, the 1-2 shift happens at maybe 10mph. Very quick & crisp, but almost too soon. Accelerating up to say 45 mph, however, and it does not want to shift into 3rd. I can hold the speed steady with no throttle movement and it will often remain in 2nd. Let off the throttle a bit and it will shift. This shift is also quick & crisp. This whole engine & trans combo is new, so I have yet to really romp on it.
I have adjusted the throttle pressure lever both ways (less slack @ WOT, and more slack @ WOT). If I dial in less slack, it won't shift into 3rd. More slack and the 2-3 shift will happen around 40 mph, but it goes into 2nd not long after the car starts moving.
Obviously the combo is far from stock, so I am left wondering if this is to be expected? I have contacted my transmission builder, and he offered to build a new valvebody for me - which I appreciate - but I am reluctant to conclude that the valvebody is at fault. Could I have done anything wrong when I rebuilt the trans? Could the governor be the issue? I would rather not start pulling the trans apart only to find that these shift points are "the nature of the beast".
Your thoughts? Thanks.
