- 4:10 PM
- Apr 13, 2012
- Granite Bay CA
Hotter than this?I live in a very hot climate.
I use just a good 19" factory 7 blade fan and shroud and have never overheated.
same on my charger now, efi controls fans and its pure joy. pull fans im using from oem fans from mercedes , very strong, each has 30amp relay, blow like a champ. Nothing can beat oem fans. But i will need to see what do i get as AC pusher, btw, is this good combo ? 2 pullers behind rad, 1 pusher in front of condenser? dont they fight with each other?I have bought several Be Cool fans, and they were Spal fans with hardware. Listed cost was about the same, but Be Cool had a rebate at the time.
Dakota digital had a fancy programable fan controller with blue tooth if you need to control 2 fans at different temps.
I used the older non-bluetooth version before installing the EFI that controls the fans now.
