Aron Gleason
Before I tore into the 440 to replace the cam and lifters and timing chain my autometer afr gauge worked the way it should. After I got the motor back together the afr gauge will stay at 14.7 once it's done it's normal countdown, everything is hooked up the same as before. I thought the sensor might be bad so I replaced it. But it will do it's countdown then go to 14.7 and it won't move from there even if I rev up the motor. What could cause that?
