after market Oil pan issues
BlooDSMeaR
1:36 PM
Medford Oregon
I have a new
Milodon Street and Strip Oil Pans 30941
to install into my 73 roadrunner. I have read some people have had issues with it fitting in the k-frame. is this operator error or do I need to get something else that will fit correctly?
I don't know your answer specifically, but that is a race pan in my opinion. Here's a couple thoughts.
a. Ground clearance will be poor. If you live with smooth roads around, highway, etc. then no problem. If you live around a lot of potholes or dirt roads, not so good.
b. IF you have to put a dent in it to clear the k-member, no problem. I mean, you have a 7 quart pan, so what would a couple ounces matter?
Hopefully someone else here is running that pan & knows better than I do.
