Meep-Meep
дворянин
I just pulled my 6 BBL carbs off my 440 to make adjustments and here is what I found: Both outboard metering plates are stagger jetted with the smaller orifice on the diaphragm side. Best I can measure I have .086" and .095" on both front and rear carb and at WOT in high gear on a dyno pulling up to 6000 RPM it was big time lean. The center carb had 61's both sides. My plan is to open up the outboards a little while maintaining the stagger jetting. The front carb will be jetted to 63.
What I noticed about the idle when I first put the 6 BBL on is the small amount the center carb needs to be open to get a normal idle. I'm running a very mild cam and get 12" Hg at idle so for the most part this is an OEM carb friendly engine. The outboard carbs do have an idle circuit and I found they contribute quite a bit to the idle fuel. I also found it extremely important to make sure the safety linkage puts pressure on the outboard carbs to ensure complete throttle blade closure. If you can wiggle the outboard throttle shaft with the center carb throttle closed you will not have a consistent idle. My carbs are NOS later model replacements and the mixture screws on the outboards are still sealed with lead plugs and at this point I see no reason to tamper with them.
Over all my car runs great on the center carb but is weak when you mash the pedal. It will still roast the tires down to the rim if you let it but I think there needs to be something more, and the dyno run showing a nearly 18:1 AFR proves it wants more fuel. I was also fighting a huge hesitation at the track so that's more proof that I'm not picking up enough fuel.
