I am in need of replacing the oil pan on my 1962 Plymouth that runs a modified 440 (stock stroke). I developed a "little hole" in it yesterday....:angryfire:
The pan that has been on it is one of the Milodon 9" deep rear sump pans that holds 10 gts of oil with the dual line pickup and has the tunnel for the steering link to go through. The motor placement is at least close to stock since the steering link fits into the existing pan tunnel.
I need a pan that is not as deep and looking for recommendations. The oil pump is one of the Milodon hi flow units. My motor makes 650-700hp and will occasionally see some strip time but mostly street crusing and messing around. Can I get away with a single pickup and plug off one of the lines? What other dual pickup pans are out there that can give me significantly more ground clearance? Thoughts?
MAGE:
