Air Compressor inop
Frankb
3:35 AM
Tucson
My 40 year old Craftsman 30 gallon 5 hp compressor failed. Getting power just wont start up.
Was running fine. It starts and stops as you use air. Noticed my high speed was slowing down and did not hear the motor running. Thought it might have overheated so put a fan on it for an hour. Still no start.
Any ideas on what to look at?
This machine has run flawlessly since I bought it from Sears in about 1985. Man the stories it could tell...
I have a 5 year old Husky that i recently had to replace the capacitors on. You got lucky for that length of time. My old craftsman blew out the reed valves. Buy the capacitors on line cheaper..
I would check the pressure switch (aka: 'points)... usually located under a cover that the wires go to. The contacts can get corroded, just like an old distributor. It's where you can also 'tweek' the max pressure build cut-off.
Start at the pressure switch. Make sure you have power coming into the switch. Then check there is power going to the motor. If power in, but nothing out, bad pressure switch. If power in and power out then the problem is the on the motor side. Usually a starting capacitor problem. Usually if the motor is locked up, it will draw to many amps and trip the breaker.
Buy made in USA electrical parts cheap does work but it can cost ya.
When looking for parts it helps if you can determine who manufacturered it for Sears. Mine was made by Cambell Hausfeld. I had to replace the pressure switch on it. Picture of the unit would help with the diagnostic.
If you drain the tank and it runs, my bet is the pressure switch. If it doesnt run at all the start capacitor is high on the suspect list.
I know everyone is trying to help.
But the first thing to check is that you can turn over the compressor by hand. If it's siezed up then the pressure switch and capacitor won't help.
If you can't rotate it then disconnect the belt and the motor will likely run fine.
Then you'll need a new compressor head.
the motor and pump both turn easily by hand using the belt.
I have manual that came with the compressor.
both capacitors look good. I thought a capacitor expanded when it went bad??
I did not check power to pressure switch - i will do that and go from there
if nothing else at least i have an excuse to get a new compressor
No way to tell if a capacitor is bad by looking at it. If all else checks out, that’s your next move.
you can test the capacitor with a good multimeter. Select ohms, one probe on each post of the capacitor. Should get an ohm reading that will climb up or down. If you read open, capacitor is bad.
I tested both capacitors. I use Fluke 115 meter. It will read capacitance.
One capacitor is GE and the other Phillips.
GE cap label says 25uf + or - 6% and meter reads 24uf but reads open in Ohms
Phillips cap label says 216-259 ( I'm assuming this is the microfarad range but I'm not sure because there is no uf symbol after the numbers) ) and meter reads 232uf and initial 2.99 m Ohm that continuously rises so I am going to say this one is good
So i will replace ge unit and go from there. If still not run, well then maybe new compressor is in order
I don't know if it makes any difference but ge unit is a run capacitor and the phillips unit is a start capacitor
Sounds like your on the right track. There is a difference between a run capacitor and a starting capacitor. So make sure the new one is the same as the one you are replacing.
Well, replaced cap that was checking bad (bad via ohms check, good via uf check) and still no start. This was the run cap.
The other cap is now checking bad via ohms check but good via uh check
Another thing the cap that i replaced is now checking good via ohms check and uh check
Think I should replace the other one? Its 25 dollars at the local electrical place
My similar Craftsman compressor is a couple years older than yours, it had the same problem, and was fixed by replacing the start capacitor.
I ordered a start capacitor. Should be here tomorrow. If this doesn't fix it then a new compressor. Black Friday just around the corner.
You know you never know how much you miss something until its gone, not working, ...
I still haven't seen if you checked the pressure switch. Very easy to check and see if it has power. If it has power but doesn't power the motor side of the switch, it's a cheap easy fix.
