Meangene83
1973 Plymouth Roadrunner
383 engine
The ignition harness was roached... So I got some Molex connectors and wired them in as a replacement.
2 separate connectors of totalling 8 Connections. (just like the orig)
I wired it up exactly as it was before... except the Blue striped and Double Blue Striped. Before replacement they were twisted together and going into same point on the harness. Based on my wiring diagrams, these two 22Gauge blue wires are for "key buzzer"?
NOT PICTURED. A PINK Wire is spliced to the RED (battery?) wire on the harness. Off camera
What is this PINK WIRE?
What happened is this... added new molex connectors... Fired up the engine... Turned on headlights, and noticed the Dash Gauge lights were Super Bright, where as before they were very Dim.
As I rev'd the engine a couple times the brightness seemed to fluctuate with the engine rev.
Then... DEAD. No gauge lights, no head lights, no tail lights, no blinkers. No flashers.
All of these items Worked BEFORE the molex connector swap.
(Note: the dash gauge indicator for both Blinkers was blinking, and I could hear the Flasher Clicker.)
Also if I stomp the Headlight switch on the floor by the brake, the Dash Indicator light comes on/off in sync)
I then broke out my tester, I figured I blew a fuse.
I checked each fuse (SEE VIDEO)
#5 NEVER SHOWED ANY POWER. (engine running, or engine off with key in full forward position)
#2-3-4 showed VERY BRIGHT
#6-7-8 showed very dim with the tester.
Does this matter???
I tried to identify with my Plymouth Manual the Fuse #'s, but the book didn't seem to match up to what I had physically in front of me.
Basically I need some help with where I should look. I have no experience with old Mopars but am quick to learn. Thank you for the help...
VIDEO
http://youtu.be/ngvrGjEq9l4
383 engine
Does this matter???
VIDEO
