almost done
Good luck at the track ! I hope to go to the track on Oct the 18th or the 25th as I have not decided which weekend yet. Let us know how you make out ? Ron
well went to the track did not go as planned first pass wire came off ballast resistor about half track 2nd pass it was running out of fuel and bad bog off the line I see bigger fuel line electric fuel pump and better carb tune coming this winter then see what it does come spring
the day after we went to the track I also found out that a head gasket was blown no damage just the gasket fixed it now we will see what is does now
well back to the track forgot washers for the wheels with the slicks on so ran it with street tires came out soft still spun for 30 feet granny shifted it and still ran 102 mph i said not bad for soft pass what do you guys think
Sounds like you have a runner, certainly more in it...
Good luck & Happy Moparing
hay GetX'd it has a 440 it is 30 over ported 440 source heads 10.5 compression comp cam solid lifter lift is 559 /252 at fifty 108 center torker2 intake 850 demon 4speed 410 shore grip hope to run mid 11s
