Lazerwolf
Have a 74 Charger with a 400. Normally alternator needle sets steady about in middle of gauge. Last Friday took it to a local show about 10 miles away. On the way there, needle moved clear over towards C, like it was charging a ton. When I got back, looked for any loose connections but found none. Monday took to a local shop to have it checked about a 1/2 mile away. Needle was wavering slightly near middle but not charging like it was. Shop checked voltage at battery and it was between 14.4 and 14.7, which he said would be normally after just starting it. Battery was in car when I bought it 3 years ago so they checked that. It was down a few amps, 650 amp battery and was something like 590, so he said that was not a problem. Original voltage regulator died last year so that was replaced. Also replaced alternator because one on car when I bought it had back of casing cracked, like it was dropped. Any thoughts? Loose connection in dash? Any help would be appreciated.
