Outlaw525
This is a Griffin 26" 2 row. Drop in, used factory shroud, looks close to stock and works great. My 472 hemi runs at 190 degrees even when it's 95 degrees outside.
View attachment 1662851Nice, did you drill and tap that other hole in water pump housing?
Champion makes a good radiator. I've been running one in AZ for 10 years now cooling a .060 over 440 with no issues.Just found this one also lol been looking all weekend when I had a min
Hmmm. When I put that number in on Summits site, there were several complaints of the stock shroud not fitting do to the mounting studs being placed wrong. One of the people who had a bad result is a known heavy Mopar gent down in San Diego county who knows his way around cars.While not Aluminum these seem to fit very well with the stock shroud.
[/URL]
Brand:
Summit Racing
Manufacturer's Part Number:
SUM-382026
Part Type:
Radiators
Product Line:
Summit Racing™ Classic OEM Radiators
Summit Racing Part Number:
SUM-382026
UPC:
190861063754
Radiator Material:
Copper/Brass
Radiator Style:
Downflow
Transmission Cooler:
Yes
Inlet Location:
Upper passenger side
Outlet Location:
Lower driver side
Overall Width (in.):
28.00 in.
Overall Height (in.):
23.25 in.
Overall Thickness (in.):
3.50
Row Quantity:
3
Radiator Finish:
Black
Core Width (in.):
25.00 in.
Core Height (in.):
17.50 in.
Core Thickness (in.):
2.00 in.
Radiator Inlet Size:
1.500 in.
Radiator Outlet Size:
1.750 in.
Trans Cooler Adapter Fittings Included:
No
Tube Size:
1/2 in.
Fan Included:
No
Radiator Cap Included:
No
Quantity:
Sold individually.
On a drive it got to 175-180 I have another thermostat that’s 180. I’m having the sniper tuned in the morning so maybe I will switch after that.I would suggest a 180 deg. thermostat 165-170 is a little low.
You can actually get more wear running too cold.
I have the same radiator in my Plymouth.
So far it works well.
May have some for you.I need to figure out a way to clean up my spark plug wires. I just can’t seem to find any good holders. I have good ones that are at my valve covers but I need the other ones
That would be Sweeeeeeet. Got that newer power steering pump installed also it works great with that modern gear box from Steer and Gear I got. Wheel moves like butta lolMay have some for you.
