Turbobus
yeap, but is interesting how 71 and 73 diagrams shows somehow diff ways to make it.
73 with the splice into the R6A line to still going throught the bulkhead ( with a fulse link too ) to feed the main splice ( edited diagram to show that ), while 71 diagram is more "simple" and a bit of lack of info on diagram
I’m going to modify my harness to delete the questionable bulkhead connections. Everything looks pretty straightforward,As mentioned, it refers the factory bulkhead by-pass, commonly referred to as the factory “Fleet” by-pass as it is mostly found in fleet production (Police/Taxi) with a high output factory alternator. The matching engine compartment diagram is on page 8-128 in the ’73 Dodge manual. The original dash harness ammeter leads were to be cut and taped off with the factory by-pass. By the mid to late seventies the factory was quite aware of the weakness in the charging system design at the bulkhead connector. Especially on C-bodies (there were bulkhead by-pass recalls) and other high optioned cars running more electrical loads.
Agreed, plenty of discussions about the ammeter/charging systems here, do a search.
Remove A1B-16DBL, increase wire size from alternator to 8 gage etc, but my only question is, does pin 18 share R6-12BK, which will now be called R6-8BK, with the new R6C-12BK. Can the connection be made anywhere before the fusible link?
Do you know anyone that’s done this?
Please forgive my ignorance with schematics, might as well be trying to read Japanese!
Thanks, in advance for any help you might have.
