Any clues where I can find a 64 Dodge 440 Accelerator cable
john perez
12:41 AM
CT
How lucky can one get? While I was starting my 64 dodge 440, max wedge, working the throttle is a must, the accelerator pedal went to the floor, and stayed there. Yup the throttle cable broke. I took it off and it measures 20 inches from the hole in the connector to the other hole in the connector. Does anyone have a source for this part? I can't find any numbers on the part which makes it more difficult. Any help will be appreciated.
Here are some pics.
You have a max wedge WOW.......................that should not be a hard part to find.
Does anyone have Joe Suchy contact info?
Just highlite his name n move it to new tad on screen n the internet will do the rest
Thanks all for your reply's, its good to know who the good guys are when parts are needed. I ended up getting the cable from Mancini Racing, because the length I needed was specified in their chart. I ordered on line and for some reason the order never went through their system. I called them a couple of days later to check and they took the order on the phone, charged me for UPS ground but shipped it FED EX express at no extra charge and I had it in two days. Worked out very well. But here is the amazing part these days, something unfortunately rarely seen.........
A tip : My 64 dodge stock 318 poly throttle cable was to short when I put a 440 with alum. high riser intake and Holly double pumper on. I used a cable from a slant six and it worked very well...............MO
I had the same issue and tried a /6 cable. Way too long. I then ordered a cable from summit, which was the length I needed, but was junk as it had plastic cable sheath ends. I ended up using various components and a swage tool to terminate the cable. Worked out great, buy what a pita.
The Mancini +1" was barely long enough for the RPM manifold height, but I changed the kickdown set up to lokar and triggered this adventure.
20200722_191753.jpg 20200722_191802.jpg 20200722_191809.jpg 20200730_214005.jpg
Ooof. Wish I would have seen this sooner. I just bought the Mancini max wedge cable and its too short for my single plane application in my savoy. Carb spacer,
