Anyone know what these harnesses are for
Pratty
9:24 PM
Australia
Hi all, my 68 Charger came to me as a stripped out shell with some 69 parts. I think there were even some Challenger bits in the trunk. I've not done one of these before and am at a loss to figure out if these two wiring harnesses even belong to my 68. Any thoughts would be gratefully received. Thanks in advance!!! I've got a similar problem with some weird looking vacuum lines and connectors but I'll get to them later.
as far I can tell, A body up to 72? Map Light along with some other accs included on same package. Those sockets are at least the kind of sockets used on A bodies for Map light option installed underneath the dash frame, and the female nude terminal the one is to be attached on acc bus bar on back of fuse box. (not E or 7X B bodies fuse box design, neither 73 and lates A bodies)
Same bulb socket used on E bodies map lights but that nude female terminal discards an E body setup
Thanks Nacho-RT74, I'm starting to gain confidence that they are not from my 68 Charger since they don't belong out front in the headlights and marker lights loom, nor the tail lights loom, both of which I have. They're nothing like the center console lights that I can see on line (I don't have the loom for them) either. Thanks again for helping me out.
I’m not really sure is really A body, but certainly is a Map light setup (along with some other accs/options)
I have been searching A body map light harnesses, and they are kinda different.
