Anyone know where there's an AMD driver floor for '70 Charger?
Triplegreen500
8:03 PM
western Maryland
I've had one on order for a while. Knew it was out of stock. Emailed earlier today and got a response "sometime in May"...
Front floor section, under the driver seat. I really only "need" the rearmost 8" of it as my back seat footwell is where the rust is (and I already have the rear seat floor piece)...it just took out the rearmost few inches of the front floorboard as well. I have some pinholes near the pedals up front, so having a whole floorboard is "nice"...but not needed right now.
Anyone know of any vendors who have 'em in stock?
Not much help. However, I need this same piece for my Road Runner someday soon.
Try "The Speed Shop" in Toledo Ohio. The last time I was there they had AMD 66-70 B body right and left side front to rear floor pans and I believe he was asking something like $100 per side. He only had one set of them. I thought about buying them just in case.....but I don't plan on doing another B. He's more of a GM guy but has inventory of all makes and models....he's had these pans for at least a year and a half.
https://www.thespeedshoptoledo.com/ 419-356-3179
You can try Stephen Performance in AL. They are one of the largest AMD dealers around. Good Luck on your search
I had around $4k in my cart, when I logged in to find things dropping out of stock. I got the same song, “April” or “May”. I ended up searching the part numbers on eBay and found Jegs to have the items AMD showed out of stock. This is for a RR, so you may not have the same luck....
Everything except that driver rear footwell is solid and shiny factory paint on my car. I suspect it was a carport car, driver side exposed, and the quarter window leaked - that's all I can think of, to have this sort of damage, and have it this localized.
I checked jeg's - "ships direct from the manufacturer on 4/1/21". I've emailed Stephens - thanks for the tip!
Underseat is spotless on mine - only the low point of that back seat footwell rusted out, but it took out the rearmost few inches of the front floor panel as well so I need to get that so my body guy can decide "whole piece" or "just the back section".
I will need trunk pans at some point (center/low section is bad, but the extensions and the upper part are perfect)....but right now I want the interior floors done so I can drive the thing come springtime!
Pm sent
