Anyone using K1 rods on a 440?
Danny Baker
12:00 AM
Fort Wayne, IN
Looking for K1 rods/bearings recommendation. I'm planning to use standard-type bearings, but noticed their spec says "use CB727 bearings". I've Google-searched every combination of CB727, but the only bearing I'm finding is a CB727P which is listed for a Triumph Spitfire.
No answer on their tech support (in Ohio), I suppose they are shut down for the virus.
So just curious if anyone has gone down this road, and ran into any issues with bearing choice for K1 rods on a 440.
If it’s a factory B/RB size journal, the bearing number is CB-527 in Clevite. If it’s an aftermarket crank, you’ll want to use CB-527HN which is a narrower H series (eccentricity) bearing to accommodate the larger radius fillet on the journal. If it’s Chevy size (2.200) then it’s a CB-743 and the same suffix info applies.
Thanks, yeah 527 that's what it had on it. Just wondered if those rods had some weirdness I couldn't see.
I do not see where it shows a bearing number on their website. A CB527P rod bearing is 0.912" wide, and the rod big end width is 1.017", so it will fit okay. As Hemirunner said, a CB527HN (0.862" wide) bearing can be used on a stock or aftermarket crank. The narrower bearing allows for the larger (0.125" radius) of HP cranks. The stock CB527P bearing can only be used on a stock crank as it is too wide for the large radius HP crank.
Thanks for the info 69Bee. Working on the engine is a great stress-reliever right at the moment.
