WTB B Body Oil Pan and Pickup, various OEM nuts and bolts needed
DieselPower
9:46 AM
Deer Creek, IL
Feedback: +1 / =0 / -0
Hello,
I am doing some work on my Dad's 69 Coronet R/T to make it more original. I need the following:
1) 440 B Body Oil pan (stamped 402) and matching pickup. I will be removing what I believe is a Milodon 7 qt. pan and pickup if anybody is interested in a trade.
2) I need some three point castle nuts. I need two for the upper ball joints and one for a tie rod end.
3) I also need one correct horn bolt. Should have an attached washer with teeth.
4) Nuts for upper control arm cam bolts. Cam bolts and washers are good, but the nuts have been replaced somewhere along the line with hardware store specials.
5) AC compressor brace that goes from compressor to coil mount hole for 440.
6) Lead wire off of single points type distributor. Basically I am going to splice this wire on to a Pertronix lead wire to make it look more original.
Thanks for looking!
E-bay. I have seen all those parts for sale. Be patient and vigilant and you'll find them all.
Hello all.
I found that new horn bolts are pretty cheap, so those are no longer needed.
I know it is a longshot, but I was hoping somebody out there might have a used original ballast resistor (PN 2095501) that is in decent shape. I am going to bypass the resistor wire since it is not needed for my setup and I really didn't want to modify a new $40 part.
Thanks!
I have a brand spanking new "402" oil pan that I just recently bought from Classic Industries for $160 with one of their discounts. I painted it hemi orange with high temp paint (2 coats of high temp primer and 3 coats of high temp paint). Brand new but wouldn't fit with my oil pick up so I used a hemi oil pan instead. I'll sell it to you for $130 including shipping in the same box that I got it in from Classic. Just shoot me a PM. Thanks
440source.com has original 402 pans they pull and sandblast all the time. I bought one from them and it was in great shape and cheap!
