Have a 1973 Doge Charger and neither back up light socket has power coming to it. The car will crank over in nuetral and park so don't think its the nuetral safety switch. All other rear lights work. Ant suggestions?
I did look at the fuse box under the dash and nothing appeared to be burned. It was late though and will look again today. Do you know which fuse would be the correct one?need to say.... they are on a fused circuit before leave the cab going to the NSS... have you checked the fuses ? can't recall which one it is specifically at this moment
You need to at the very least get a owners manual and better yet get a factory service manual and read.I did look at the fuse box under the dash and nothing appeared to be burned. It was late though and will look again today. Do you know which fuse would be the correct one?
Or at the very least check all the fuses if you can no longer read what each is labeled. There ain’t many in there. FSM is always our friend.You need to at the very least get a owners manual and better yet get a factory service manual and read.
Right......And not by just looking at them and saying they are OK. Get a test light or voltmeter and check things the right way.Or at the very least check all the fuses if you can no longer read what each is labeled. There ain’t many in there. FSM is always our friend.![]()
Thanks for all the suggestions. I was finally able to spend some time troubleshooting. Down at the connector, putting a jumper wire between the outer terminal sockets with the car in reverse and ignition on did not resolve the problem. Still no back up lights. Checked the connector, one outer terminal socket at a time and neither had voltage coming to it. Pulled both 20 amp fuses in the 7 & 8 position and checked them for continuity. Both checked good. With each fuse out I checked power coming to the fuse clip. Both locations check about 11.5 volts. I also checked power coming to the mid terminal port on the NSS from the starter relay. Measured 11 volts. If I'm not getting any voltage at either of the two outer connection points, the wiring diagram shows both wires going back to 7 & 8 on the fuse block. Is the next thing to check continuity through the wires from the fuse box (inside) to the bulkhead connection in the engine bay? After that, check for continuity in the wires between bulkhead connection and the NSS connector? Any suggestions?.
