Grabinov911
Ok guys. I'm usually pretty good with math and diagrams, but the relationship between backspace and offset seems impossible.
1. Backspace is easy because you can measure it. It is the distance between the mounting surface of the wheel and the inner rim lip. Stick a ruler inside the wheel and a straight edge across the inside of the wheel and measure. On a 10" wheel, if this distance is 5", then the wheel is centered on the hub, with 5" inside and 5" outside.
2. Move the mounting surface outward - toward the outside of the wheel - by 1" and you should have a backspacing of 6". With 6" inside of the mounting surface there should be 4" outside - after all, the wheel is 10" wide and 6+4=10.
In #1, your offset should be 0mm. In other words, the mounting surface IS NOT OFFSET from the center of the wheel.
In #2, your offset should be 25.4mm, or 1". In other words, the mounting surface IS OFFSET 1" OUTSIDE from the center of the wheel.
But that isn't correct using the backspace calculators on the internet. Here's one: http://www.mrw-wheels.com/wheel tech/offset chart.html
Put in a 10" wheel with 0mm offset and the backspacing shows as 5.5". How is that possible if the mounting surface is in the center of a 10" wheel? Worse, how can the backspacing be 5.5" and the "front of wheel" be 5.5". That adds to 11" and the wheel is only 10" wide.
Put in an 8" wheel and the same is true! The total backspace and front space is always 1" greater than the width of the wheel. WTF?
I am desperately trying to find a set of wheels for the track for my car, but I can't figure out what size to order for the life of me!
