@ Photon440,
the hiss sounds like it is coming from the brake pedal area and is constant unless pedal is depressed. The brake booster seems to work but I feel that their is a vacuum leak affecting performance elsewhere as well.
I will disconnect that line tomorrow and see how the fluid flows. If it flows well, I'll check out that wheel cylinder.
I should have been more specific when I said "garbage". It appears to be running rich, has low power, was backfiring for a while before I got the fuel flowing a little better. It had an electric fuel pump near the gas tank that I assumed didn't work so I took it off. The thing does fire up without any pumping of pedal. It has been sitting for a little while so I was told the carb may need to be rebuilt and cleaned, but it has never really ran very well.
For the wheel, I think I'll get a 2x4 and butt it up against the wheel and wail on it with the biggest sledge I can find. I believe it is a ford wheel on there anyway. needs to go lol.
The harness is a brand new one from YO. The motor is a 440 so I bought the big block harness. All my dash wiring is a mess with all aftermarket gauges and very little left factory wiring. I have a new cluster sans a tac on standby. Hopefully it works.
The exhaust system looks like its the original system. Holes in both mufflers and bad passenger side manifold gasket. In retrospect I should have replaced it instead of buying brand new magnums. I would like to do 2.5in pipes with thrush mufflers and R/T tips. Glad and sad to learn that could be affecting performance.
And I just thought of another thing: My steering wheel has a lot of play in it and I heard you have adjust that out. Do I need any special tools for that? Anyone know if a good how-to thread for that?
Thanks Photon440, I hope this info is more specific.
@ Bb70Charger500,
Thanks. You were very helpful. I will check the brake line out and see whats up.
I replaced the gasket with a cheap rubber one from Oreilly's. I siliconed both sides of it and let set for 24hrs. I added fluid tonight and so far, so good. I haven't taken it for a drive yet, but I will tomorrow.
On the wires and tire, I will do just that. I did print off a nice wiring diagram that is very helpful. It looks like its just gonna be a matter of removing ALL of the crap wires the previous offender -I mean owner- left.
@ 747mopar,
I did replace the hose, still have the hiss. I'm guessing a seal in the booster somewhere. Are those difficult to work on, diagnose, and fix?
Will do with the brake line hose.
I laid it on my counter top and it was FAIRLY straight. Not completely flush but the difference wasn't bad enough to alarm me. Very subtle. Plus its all I have now lol. Its a 3in deep pan that came with my rebuild kit.
I looked into Hagerty and they wouldn't give me a quote because it's a driveway car
. I may be able to move it to my girlfriend's parents' shed though. I did fib on a quote and said it was a garage car and it quoted me $700 something a year for I think 12 or 15k coverage. I should mention the car is a beater and in slow restoration. There are pics in my gallery.
@ CarNut,
Its good to hear from you!
I think the NSS seal was replaced when it was rebuilt last month. I'm positive it was the seal. It was squishin' out of the gasket and the bolt holes like a mo-fo. I think I overtightened it when I went under there to snug em down after maiden voyage. I will double check that neutral safety switch though as you are wise mopar guru.
Thanks! And thanks for the service manual. Added to favorites.
@ BeatersRus,
I have a deep pan now so I gotta stick to them after market suckers now. I do think if I keep having problems, I will order a nice billet piece. I bet they're pricey! lol
I will work on that header leak ASAP. I don't have the funds for the holes in the mufflers, though. Will fixing the header gasket leak get me by for now?
Will do with the wheel!
And thanks for the heads up. Yeah I'm pretty nervous about losing something in that electrical system, but nothing works for the time being so I don't have much to lose lol. Except ignition!
Thanks!
@ CoronetDarter,
Thanks sir I will do that! Good idea.
@ 451Mopar,
Definitely going to look into that. Would you recommend new booster or fix the old one?
I will probe that bleed port and see if it gets anything moving.
I will check all of those areas, although I think all those seals were replaced during rebuild. I am pretty certain the fluid was coming from gasket and bolt holes but I will double check all that.
Is there a how-to forum you've come across for that kind of carb service? I'm a noob with carbs to say the least.
The car is more of a weekend cruiser/project. I'm just trying to get her solid and complete and enjoy a carefree cruise.
Great idea with the torch. I will try that if the block and sledge fail to jar it loose.
Yes sir I got the diagrams. They are fairly easy to read, thank heavens.
Thanks for all the help 451Mopar! I am from Pueblo, CO. Moved to Ft. Collins, but my car sleeps at my mom's house in Pueblo. How about you?
Thanks everybody for all your help. You are like having living cheat sheets! Let me know if you have any more questions and I appreciate all the help! :headbang:
